Render slave renderign the wrong camera
  • Render slave renderign the wrong camera
    Hi there,
    I couldn't make the render slave read the same camera I have in the server... for nothing!!
    Any ideas on how to go about this?
    Here's a sample, sorry but I had to blur the image due to confidential nature of the work, but you'll see there's something wrong with the buckets...
    you know what, I did a few other tests and it seems that the render slave is rendering a different model than the server... CRAZY!!
    Is there a way to dump the renderslave memory before each render?!
      That's funky! Sorry not helping...
        I know! Do you think my client will like it?! I mean, it's some form of post-modern-cubism... :P
          Does the problem persist if you restart V-Ray render salve on the node?
          Zdravko Keremidchiev
            hmm this looks like a problem we used to have in vray for max when dr was first introduced.. if you cancelled a render before the end, the slaves sometimes didnt reset, and next time you rendered youd get bits of a previous scene or camera coming through in your render. at the time we fixed it with a vb script to restart the vray spawner on all slaves with a desktop shortcut. however its not been a problem in max for a while and there is even a tickbox to restart the slaves when the render finishes.. i didnt try vray for maya so i dont know if you have this tickbox?
              I consistently have the same problem with that file specifically... I'm currently using DR in another scene and it works fine.
              Actually I was about to post an issue with irradiance map buckets from the slave machine rendering with different light intensities... but i'm just testing with a single machine render to see if it still happens and if it does, I'll post something.
              cheers
