Houdini to Vray
  • Houdini to Vray
    Using the command line utility, we aren't having much luck getting motion blur to export.
    Is there some sort of magic trick I need to know for bgeo to vrmesh?
    You need .geo, not .bgeo files; and they must contain vertex velocity information.
      Hey!! Where can I find more info on this workflow (houdini to vray)?
      Thanks a million!
        Yeah, I meant to say .geo. Thanks Vlado!!!!! Woohoo!!
        Aneurisma: There is a plytovrmesh.exe tool to convert .geo exports from Houdini into a proxy that can be loaded into maya. Once you write out a .geo sequence with velocity, you can go to the Vray Menu, import proxy in Maya.
          Hello !
          I have an Houdini scene that I can't convert to vrmesh (ply2vrmesh).
          I tried all 4 formats :
          -bgeo
          -bgeo.gz
          -geo
          -geo.gz
          I get this :
          Error writing file: Wrong .ply format
          Or this :
          Error reading file: [VUtils::GeoInterface::readFile] Error reading .geo file at line 9990: Unsupported number of polygon vertices
          I have sent the 4 files (in a zip) to vraymaya@chaosgroup.com
          Thanks.
          PS : it is houdini-11.1.67-win64 demo version, but it seems the export should work (geo ASCII version contains "PGEOMETRY V5")
            Thanks, we'll try them out, but for this error:
            it could be that you have polygons with more than 4 vertices. Currently ply2vrmesh can deal only with triangles and quadrangles.
              Yes, inspecting the ascii geo file indicates we have polygons with more than 4 vertices.
              We will try a Divide node in Houdini to get triangles and quads.
              Thanks.
                After dividing the geometry (3 or 4 vertices maximum) it now works all right.
                Thanks !
                  This is heavily Off-Topic but i read LOTS of posts that are about the houdini to maya workflow...would it make sense to ask if wee will ever see a native vray integration inside houdini? I know some guys tried this already but i don't know if they ever succeeded...
                  just curious....
                  Oli
                  OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
                    There were some discussions about this at one point, but it's a lot of work; due to the procedural nature of Houdini, render data may come in a variety of ways. We've had a similar (unpleasant) experience with ICE in Softimage, where if you set it up in one way, you get a certain result, but if you click a little option somewhere, you get something completely different that requires a different translation method altogether. If there is enough interest though, we will certainly look into it.
                    Also, it depends on what people are going to use V-Ray for in Houdini... from my understanding, a complete scene is rarely set up entirely in Houdini (would it make sense to bring e.g. in character animation there?) and it's usually bits and pieces of a scene that ultimately end up somewhere else.
                      Is there any plan to support the .geo.gz format ?
                      It's a gzip version of the .geo format, that Houdini provides when you want to use less disk space and load faster.
                      Thanks.
                        Isn't .bgeo better than that, being binary and all?
                          Well, if I remember correctly, we were told to use .geo (and not .bgeo) in order to get Motion Blur.
                            Hm, that should be working fine now in the latest builds at least on the V-Ray side. I'm not sure about Houdini - I don't think it matters if you use .geo or .bgeo
                            • #15
                              I totally understand and i think it is the right way to go NOT to build vray4houdini....i was just curious...u are absolutly right with "a scene that ultimately end up somewhere else"
                              I also feel more comfortable having maya as a shading and lighting environment...it is better for quick hacks
                              cheers
                              Oli
                              P.S.: i am really looking forward to testing the ply2vrmesh again...i always had issues converting way back in april...
