<UDIM> <UVTILE> is used with the relative path will not work.
  • <UDIM> <UVTILE> is used with the relative path will not work.
    If <UDIM>/<UVTILE> is used with the relative path (based on Maya project) will not work.
    tested Maya 2012 64bits windows 7
    [2011/Jun/8|15:17:05] V-Ray: V-Ray for Maya version 2.00.04 from Apr 28 2011, 02:33:53
    [2011/Jun/8|15:17:05] V-Ray: V-Ray core version is 2.00.01
    [2011/Jun/8|15:18:50] V-Ray: Bitmap file "sourceimages/color/blacksmith_color.<UDIM>.tif" loaded.
    [2011/Jun/8|15:18:50] V-Ray warning: Bitmap file "sourceimages/color/blacksmith_color.1029.tif" failed to load: [LoadImageFile] Failed to open file: no such file
    [2011/Jun/8|15:18:50] V-Ray warning: Bitmap file "sourceimages/color/blacksmith_color.1031.tif" failed to load: [LoadImageFile] Failed to open file: no such file
    [2011/Jun/8|15:18:50] V-Ray warning: Bitmap file "sourceimages/color/blacksmith_color.1032.tif" failed to load: [LoadImageFile] Failed to open file: no such file
    In absolute path, it works fine.
    [2011/Jun/8|15:23:05] V-Ray: Bitmap file "D:/testproj/sourceimages/color/blacksmith_color.<UDIM>.tif" loaded.
    [2011/Jun/8|15:23:05] V-Ray: Bitmap file "D:/testproj/sourceimages/color/blacksmith_color.1029.tif" loaded.
    [2011/Jun/8|15:23:07] V-Ray: Bitmap file "D:/testproj/sourceimages/color/blacksmith_color.1031.tif" loaded.
    [2011/Jun/8|15:23:09] V-Ray: Bitmap file "D:/testproj/sourceimages/color/blacksmith_color.1032.tif" loaded.
    Please check and fix.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Are you sure this is specific to tiled textures? Does it happen with regular ones?
      Any textures occur.
      It does not relate to a format.
      I tested for the foundry site
      http://www.thefoundry.co.uk/products/mari/training/
      This DOWNLOAD contents.
      http://thefoundry.s3.amazonaws.com/p...ithObjects.zip
      http://thefoundry.s3.amazonaws.com/p...Textures_1.zip
      Step by Step.
      Project folder:C:\testproj\
      Project source images folder: C:\testproj\sourceimages
      1:file loader is set to Diffuse Color of VRayMtl.
      2:The texture in a project folder (sourceimages/color/blacksmith_color.1001.tif) is opened from a file open dialog.
      3:It is set to texture file path of Maya with a relative path.
      4:The number of a texture is changed into like blacksmith_color.<UDIM>.tif.
      5:hit render. no load texture.
      But if absolute path is inputted manually, it will be perfectly loaded after it.
      oakcorp.net
      v-ray.jp
        It's still downloading (and will be for the rest of the day it looks like ) so I can't check the scene yet. Works fine for me on a simple test though.
        [EDIT] Looks like it works for regular textures, but indeed not when using the <UDIM> flag... looking into it now.
          So this will be fixed for the next night build tomorrow.
            Thanks so much!
            oakcorp.net
            v-ray.jp
              One request.
              If a <UDIM> <UVTILE> style texture is used, whenever it changes a material parameter, all the textures will be re-loaded and a swatch response will become slow.
              If auto update of swatch is turned OFF, it will solve, but to have improved may be better.
              oakcorp.net
              v-ray.jp
                That one will be tricky; for regular textures, V-Ray creates a low-resolution texture version for the swatches in advance (before the swatch is actually rendered). However with tiled textures, V-Ray doesn't know what textures will be needed in advance for the swatch... I guess for the moment it can assume that the first tile only is needed (for UV's between 0 and 1).
