Displacing VRay Proxy Meshes
  • Displacing VRay Proxy Meshes
    Is this possible at all? Not a subdivision displacement, but a level 0 displace. Is there any way to do this?
    For now VRayProxy meshes can't be displaced or modified.
    You can just change their position, orientation and size.
    Zdravko Keremidchiev
      You can bake the displacement into the mesh before exporting it as a proxy.
        Vlado,
        I understand how proxy objects were designed to be used -- raw data for the renderer. I understand the workarounds as well.
        As others have pointed out, the cache system is pretty great as well for pipeline/asset management, except for two features - displacement and subdivision. It would be nice to export the low poly count meshes for lighting from finaling.
        Would it be possible to add a check box "treat as scene geometry"? Then the .vrscene could include the subdivision/displacement flags and re cache the geometry. Less efficient but useful for asset workflows. Might not be as hard as having .vrmesh files subdivided/displaced at render time. (Which would be even cooler!)
        This may become a non issue if there is a decent maya implementation of Alembic coming in 12.5. The maya geo cache system is really over complicated and creates an unnecessary node thicket.
        http://www.chaosgroup.com/forums/vbulletin/showthread.php?64699-Cache-Types-and-Pipeline-Design
        These other threads are requesting the same thing.
        http://www.chaosgroup.com/forums/vbulletin/showthread.php?47080-Proxy-shader-workflow-and-displacements&highlight=proxy+subdivision
        http://www.chaosgroup.com/forums/vbu...xy+subdivision
          make 2 proxies, swap them out for final render?
