hi,
when I am using the vray lightdome for hdri lighting, the environment override in the additional vray material override doesn't work. e.g. if I want a different reflection map for a special material it is not possible this way. my workaround is, to make an reflection override in the environment override of the render settings with my hdri sphere and generally don't use the lightdome for reflections. then my environment override in the material will work fine. But that is not a very smart solution. I think, there is no reason, that this should not work with the lightdome directly.
Gisi
Gisi
