Physical Camera Exposure and Image Plane
  • Physical Camera Exposure and Image Plane
    If you are using Physical Camera to match a plate using an Image plane you can't get out of not having the camera exposure effect the image plane. The only way I got around this was by creating a plane and assigning a camera projection to the V-Ray Light material and turning on compensate camera exposure at shader.
    Can compensate camera exposure be added to Image Plane, or is there another method to not have the exposure effect the background image?
    THanks.
    Instead of using an imagePlane or a geo plane, you can plug the projection node that you created directly into the background color slot in the environment tab of your camera attributes. Then if you turn off "affect background" in your render settings you should get what you want.
    David
      Thanks Scott and David for the tips. I was bothered by this before, but now I learned two workarounds.
      Jason
      always curious...
        Awesome David! Thanks.. That beats throwing up a plane with light material. Too bad DOF from physical camera isn't ignored as well.
          Hi, David,
          Have you tried this with RT? I tried the technique you mentioned and it worked for regular render. For example I change the aperture size of the Physical camera, the background plate is not affected between two renders. But if I use RT, as soon as I change the aperture size, the background turns into black!?
          ps. am using ver. 2.004
          always curious...
            V-Ray RT does not support the "Affect background" option; for the moment it always applies the color mapping as a post-process on the final pixels when the information required to separate the background is already lost.
            It is on the "to do" list to add a "compensate exposure" option for image planes though.
              Thanks for the explanation, Vlado. Looking forward to the "compensate exposure" option for image planes.
              always curious...
                Hey Vlado and devs,
                Along the tangent of the issue mentioned in this thread, is this feature incorporated already or it's replaced by other options somewhere else in the UI?
                I did a quick check in one of the newer nightly of 3.4 and didn't find any option like "compensate exposure" under physical camera or imagePlaneShpe node.
                always curious...
                  We are sorry to report but this feature is not developed yet.
                  We'll keep you posted for any updates.
                    I cant replicate this bug...Using backplate / imagePlanes and RT-ing cars is my general workflow all day, and the first thing I do when I drop a dome light in is adjust the camera exposure so my values look realistic...and this doesnt affect my imagePlane. It used to, Im sure, and I found it very annoying, but at some point (I dont remember when) it stopped happening. So as far as I can see, I cant control the imagePlane exposure with the physical camera.
                    Website
                    https://mangobeard.com/
                    Behance
                    https://www.behance.net/seandunderdale
                      It's still on the to-do list.
                      Alex Yolov
                      Product Manager
                      V-Ray for Maya, Chaos Player
                      www.chaos.com
                        rescuing up this thread to ask if there is any way of having a back plate not being affected by the tonemapping?
                        If i plug a camera projection with the plate image to the background override on render settings i get a clear match between what i get on render buffer and the original image plate... but with two big limitations.
                        We cant use the progressive mode neither use an exposure layer or any other layer on the frame buffer.
                        I understand that a post processing layer (as a color corrector or a glow pass) should affect the entire render area but i think that we should be able to adjust exposure on the rendered assets without compromising the background plate if we wish so.
                        Is there any workaround that im not aware of?
                        thanks
                          Originally posted by Matador View Post
                          thanks
                          Have you considered using masks?
