VrayBlend ?
  • VrayBlend ?
    Hi there,
    when I drag a black/white mask texture map into the blend amount, it looks like it reads the value different.
    Example:
    I drag the image file into the bump slot, with a value of 1 I get a thick and rich bump.
    I use the same map in the blend amount, and it get's thin and looses the thickness.
    Is there any known issue going on ?
    still on 1.5SP1, 2011-02-28
    thx a lot
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    I think you need to bump both materials, or you could leave the bump off and piggyback the blend shader into a vray bump shader applied last. Hope this helps
