Hello,
Two bugs I would like to report:
You can render layer override the resolution, but it seems to not change from layer to layer. What happens is, if I set one layer to be at 1920x1080 and then all layers become that resolution, if I change again at another layer, all layers change.
Another issue is that you can set the open exr output to be 8 bit via mel, but there is no option in the drop down, and I dont know if its intended to be set to that option anyway. Also layer overriding this parameter seems to not work between layers all though i remember it working sometime ago?
Thanks.
Thanks.
