ply2vrmesh seg faults
  • ply2vrmesh seg faults
    I get crashes when using .ply2vrmesh on a bunch of frames (but not all) in a sequence. Any takers?
    Terminal output:
    [bjhe@comp01 v004]$ vrm tempTrailFoamGeo_v004.0033.geo -smoothNormals
    Coverter of .ply .obj .bin and .geo files to .vrmesh files
    Copyright (C) 2003-2011 by Chaos Group Ltd. All rights reserved.
    Build from Apr 28 2011
    Converting file "tempTrailFoamGeo_v004.0033.geo"
    Output file is "tempTrailFoamGeo_v004.0033.vrmesh"
    Reading .geo fileGeo file format version: V5
    Number of points: 328104
    Number of primitives: 546840
    Number of point groups: 0
    Number of primitive groups: 0
    Attributes info: point 0, vertex 0, primitive 0, global 0
    Reading run 0 to 65535
    Reading run 65535 to 131070
    Reading run 131070 to 196605
    Reading run 196605 to 262140
    Reading run 262140 to 327675
    Reading run 327675 to 393210
    Reading run 393210 to 458745
    Reading run 458745 to 524280
    Reading run 524280 to 546840
    Reading .geo file... done
    Calculating vertex normals... done
    Number of faces: 546840
    Number of vertices: 328104
    Number of texture vertices: 0
    Number of vertex normals: 328104
    Reading voxel... done
    Subdividing voxel... done
    Segmentation fault
    Which V-Ray build is this? There was a bug with this in the official build, which was fixed since then.
      Hey Vlado!
      Thanks for the info. I've asked our tech department to update to latest. We're currently on version 2.00.04.
      /Bjorn
        Ok then; if you still have issues with the nightly builds, let me know.
          The nightly build works fine except from some segfaults on certain bgeo's. bgeos that chrashes can be outputed to geos and then to vrmeshes. As an example, here's a bgeo and its faulty vrmesh brother.
          www.bhenriksson.se/temp/threads/baseSim_surfaceWaveChrashMesh_v001.1015.bgeo
          www.bhenriksson.se/temp/threads/baseSim_surfaceWaveChrashMesh_v001.1015.vrmesh
            Thanks for the pointer; will look at this.
              This bug should be fixed in the next nightly build.
              Please test it and report if there are any problems with it.
              /Teodor
              V-Ray developer
