surfaceShader's output Matte Opacity broken in Nightlies
  • surfaceShader's output Matte Opacity broken in Nightlies
    Hi there,
    We've been running into some problems with alpha/matte problems when using maya surface shaders on the latest nightlies.
    Pictures should explain it really. There's a plane with a tiff attached with an alpha, the alpha is plugged into the transparency and the matte opacity channel of a surface shader.
    Maya
    Stable (2.00.04) Renders as expected
    Nightly (2.15.01-2011-11-29) Broken Opacity/alpha
    Can you post the scene too?
      Hi Vlado,
      I've attached a test scene with a red circle with alpha. This renders as expected on the 2.00.04 stable (Fedora 12, Maya 2011) but the matte opacity fails on 2.15.01 (2011-11-29)
      Cheers
      Martin
      alphaTestScene.zip
