Camera - 2d Pan/Zoom
  • Camera - 2d Pan/Zoom
    Hey,
    The problem is with the maya camera when "Pan Zoom Enabled" is checked. Vray doesnt seem to take this into account and renders the camera as normal.
    anyone else find that?,
    patrick
    Yes, it's not supported yet.
    V-Ray/PhoenixFD for Maya developer
      in "Film Back" is pre scale and film translate supported?
        yes they are. I use them quite a lot. Just be careful when using RT, if you change a parameter in the physical camera (if you use it), the camera will ignore it. Only with RT. It also goes back to use it when you relaunch RT.
        Portfolio: http://www.cgifocus.co.uk
          The pre/post scale is working properly but the film translate seems to be off somewhat.
          I've set 'Film Translate' to -6.30 which in the viewport looks like it should line up at the side of the frame, but when rendered it doesn't.
          Is anyone else having this problem?
            [ATTACH=CONFIG]9713[/ATTACH]
            [ATTACH=CONFIG]9712[/ATTACH]
            the problem is that your are previewing using the Resolution gate. When using the resolution gate the camera overscan get set at 1.3 which Vray ignores. So that why your render looks different (as it has an overscan of 1).
              Ah nice one Yannick! T'is all making sense now
                Have you reported this problem before?
                Do you have the exact/detailed steps to reproduce?
                Looking at our issues tracker, I cannot see any records for such bugs, so I'll be happy if you report them.
                /Teodor
                V-Ray developer
                  Originally posted by t.petrov View Post
                  /Teodor
                  Hi Teodor,
                  I think it was mentioned on the forum, some time ago.
                  To reproduce, set a camera with a physical camera attribute, change the prescale or/and the film translate.
                  Render it, all fine. RT it, should be still the same image, but if you change a parameter in the physical camera like the ISO for example, the image (in RT) will change and the camera prescale and/or film translate gets ignored, shifting the image.
                  Cheers,
                  Yannick
                    Understood, thank you for reporting this.
                    We've logged it in our bug tracker, so it won't be forgotten.
                    /Teodor
                    V-Ray developer
