We're rendering some hair with Yeti, its a 400 frame animation and we have 20 random frames that consistently crash on rendering, tried them on different machines on the farm and it doesn't seem to make a difference.
Can anyone make sense of the log error. It does the light cache pre-pass then crashes when it starts the actual render. The Warning: Invalid Geo is in the logs for the frames that render fine so don't think its that...
Thanks for any help!
Code:
Fri May 4 12:25:39 2012 - [2012/May/4|12:25:39] V-Ray: Rendering image... [2012/May/4|12:29:44] V-Ray warning: Invalid geometric normal (5.86509e-13 0 6.85784e-13) for "<unknown>". Fri May 4 12:29:44 2012 - Warning: Invalid geometric normal (5.86509e-13 0 6.85784e-13) for "<unknown>". [2012/May/4|12:29:49] V-Ray warning: Invalid geometric normal (5.81009e-13 -0 6.91521e-13) for "<unknown>". Fri May 4 12:29:49 2012 - Warning: Invalid geometric normal (5.81009e-13 -0 6.91521e-13) for "<unknown>". Fri May 4 12:29:49 2012 - Fri May 4 12:29:49 2012 - maya encountered a fatal error Fri May 4 12:29:49 2012 - Fri May 4 12:29:49 2012 - Signal: 11 (Unknown Signal) Fri May 4 12:29:49 2012 - Stack trace: Fri May 4 12:29:49 2012 - /lib64/libpthread.so.0() [0x332020f210] Fri May 4 12:29:49 2012 - VUtils::MaxHairBSDF::eval(VUtils::VRayContext const&, VUtils::Vector const&, VUtils::Color&, VUtils::Color&, float, int) Fri May 4 12:29:49 2012 - VUtils::PhotoAreaLightSampler::sampleColor(VUtils::VRayContext const&, VUtils::VRayContext&, float, float&) Fri May 4 12:29:49 2012 - VUtils::DefaultDMCSampler::sample(VUtils::AdaptiveColorSampler&, VUtils::VRayContext const&, VUtils::VRayContext&, int, unsigned int) Fri May 4 12:29:49 2012 - VUtils::PhotoAreaLightSampler::computeValue(VUtils::VRayContext const&, float) Fri May 4 12:29:49 2012 - VUtils::PhotoAreaLight::evalLight(VUtils::VRayContext const&, VUtils::BRDFSampler&, VUtils::IrradSample*, VUtils::PhotoAreaLightSampler&) Fri May 4 12:29:49 2012 - DomeLight::eval(VUtils::VRayContext const&, VUtils::BRDFSampler&, VUtils::IrradSample*) Fri May 4 12:29:49 2012 - VUtils::VRayPluginLightManager::eval(VUtils::VRayContext const&, VUtils::BRDFSampler&) Fri May 4 12:29:49 2012 - GlobIllumMap::eval(VUtils::VRayContext const&, VUtils::BRDFSampler&, int) Fri May 4 12:29:49 2012 - VUtils::DefaultGlobalLightManager::evalLight(VUtils::VRayContext const&, VUtils::BRDFSampler&) Fri May 4 12:29:49 2012 - VUtils::VRayContext::evalLight(VUtils::BSDFSampler&) Fri May 4 12:29:49 2012 - evalBSDF(VUtils::VRayContext&, VUtils::BSDFSampler*, VUtils::Color const&) Fri May 4 12:29:49 2012 - MtlSingleBRDF::shade(VUtils::VRayContext&) Fri May 4 12:29:49 2012 - RenderChannelMultiMatte::shade(VUtils::VRayContext&) Fri May 4 12:29:49 2012 - RenderChannelExtraTex::shade(VUtils::VRayContext&) Fri May 4 12:29:49 2012 - RenderChannelMultiMatte::shade(VUtils::VRayContext&)
