Urgent diag on error, log included
  • Urgent diag on error, log included
    We're rendering some hair with Yeti, its a 400 frame animation and we have 20 random frames that consistently crash on rendering, tried them on different machines on the farm and it doesn't seem to make a difference.
    Can anyone make sense of the log error. It does the light cache pre-pass then crashes when it starts the actual render. The Warning: Invalid Geo is in the logs for the frames that render fine so don't think its that...
    Thanks for any help!
    Code:
    Fri May  4 12:25:39 2012 - [2012/May/4|12:25:39] V-Ray: Rendering image...
    [2012/May/4|12:29:44] V-Ray warning: Invalid geometric normal (5.86509e-13 0 6.85784e-13) for "<unknown>".
    Fri May  4 12:29:44 2012 - Warning: Invalid geometric normal (5.86509e-13 0 6.85784e-13) for "<unknown>".
    [2012/May/4|12:29:49] V-Ray warning: Invalid geometric normal (5.81009e-13 -0 6.91521e-13) for "<unknown>".
    Fri May  4 12:29:49 2012 - Warning: Invalid geometric normal (5.81009e-13 -0 6.91521e-13) for "<unknown>".
    Fri May  4 12:29:49 2012 - maya encountered a fatal error
    Fri May  4 12:29:49 2012 - Signal: 11 (Unknown Signal)
    Fri May  4 12:29:49 2012 - Stack trace:
    Fri May  4 12:29:49 2012 -   /lib64/libpthread.so.0() [0x332020f210]
    Fri May  4 12:29:49 2012 -   VUtils::MaxHairBSDF::eval(VUtils::VRayContext const&, VUtils::Vector const&, VUtils::Color&, VUtils::Color&, float, int)
    Fri May  4 12:29:49 2012 -   VUtils::PhotoAreaLightSampler::sampleColor(VUtils::VRayContext const&, VUtils::VRayContext&, float, float&)
    Fri May  4 12:29:49 2012 -   VUtils::DefaultDMCSampler::sample(VUtils::AdaptiveColorSampler&, VUtils::VRayContext const&, VUtils::VRayContext&, int, unsigned int)
    Fri May  4 12:29:49 2012 -   VUtils::PhotoAreaLightSampler::computeValue(VUtils::VRayContext const&, float)
    Fri May  4 12:29:49 2012 -   VUtils::PhotoAreaLight::evalLight(VUtils::VRayContext const&, VUtils::BRDFSampler&, VUtils::IrradSample*, VUtils::PhotoAreaLightSampler&)
    Fri May  4 12:29:49 2012 -   DomeLight::eval(VUtils::VRayContext const&, VUtils::BRDFSampler&, VUtils::IrradSample*)
    Fri May  4 12:29:49 2012 -   VUtils::VRayPluginLightManager::eval(VUtils::VRayContext const&, VUtils::BRDFSampler&)
    Fri May  4 12:29:49 2012 -   GlobIllumMap::eval(VUtils::VRayContext const&, VUtils::BRDFSampler&, int)
    Fri May  4 12:29:49 2012 -   VUtils::DefaultGlobalLightManager::evalLight(VUtils::VRayContext const&, VUtils::BRDFSampler&)
    Fri May  4 12:29:49 2012 -   VUtils::VRayContext::evalLight(VUtils::BSDFSampler&)
    Fri May  4 12:29:49 2012 -   evalBSDF(VUtils::VRayContext&, VUtils::BSDFSampler*, VUtils::Color const&)
    Fri May  4 12:29:49 2012 -   MtlSingleBRDF::shade(VUtils::VRayContext&)
    Fri May  4 12:29:49 2012 -   RenderChannelMultiMatte::shade(VUtils::VRayContext&)
    Fri May  4 12:29:49 2012 -   RenderChannelExtraTex::shade(VUtils::VRayContext&)
    Get a newer nightly/stable version of V-Ray and it will be fine.
      Giving that a go with a nightly from 04/26, and just installing the one from last night.
      The crash log above was with a build from March 17th
        The 04/26 version worked.
        Cheers vlado
          Actually I think I spoke to soon, most of the problem frames rendered, but still have 4 or 5 that refuse the complete with the same error.
            In that case I will need a way (scene?) to reproduce this here.
              Hi Vlado,
              Is it ok to send a scene that uses yeti?
              Cheers,
              Nathan
                Yes...
