Texture reference doesn't work with projected textures (urgent)
  • Texture reference doesn't work with projected textures (urgent)
    Like the title say, it looks like texture reference (in Texturing ---> create texture reference object) does'nt work with a texture which is projected (camera mapped).
    I have shader with some projections, so it doesn't work for me...
    Is it hard to fix this ?
    Thanks
    www.deex.info
    Is there a bug ?
    Here a cube with a checker projected in a tri planar mapping. I create a texture reference :
    I set the rotateX of the cube to 44 :
    All is fine, the texture reference work.
    I set the rotateX of the cube to 45 :
    www.deex.info
      It works fine here. Which V-Ray for Maya version is that?
      Can you attach the scene?
      Zdravko Keremidchiev
        V-Ray: V-Ray for Maya version 2.25.01, revision 21941 from Jul 4 2012, 00:33:01, Maya 2012 win64
        Here the scne :
        https://rapidshare.com/files/43664387/bugTextRef.zip
        Set the rotateX of the pCube1 to <= 44 : work
        Set the rotateX of the pCube1 to >= 45 : does not work
        www.deex.info
          Hello ,
          We are not sure if this issue is related to Vray or Maya itself , cause Maya Software , and Mental Ray produce the same issue !
            Originally posted by svetlozar_draganov View Post
            Hello ,
            Yes it is very stange.
            And i saw the problem is just on the tri planar projection. I don't know if we can create a work-around.
            www.deex.info
              Im having a similar issue with vray proxy, but I think it maybe just vray proxy does not support texture reference object? is it possible to extend support for this feature?
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
                Do you want to use another proxy for the reference, or just a mesh?
                  Since a texture reference is a pure maya connection I think a regular mesh should do the trick. In my case I just turn on "display full mesh" for proxy and make a texture reference from it, so what maya does is just copy the transform/shape node and make a connection from it to the original shape.
                  Dmitry Vinnik
                  ShowReel:
