Here's what I discover today.
I was working on a scene, simple one, and I was using RT. Car, two lights, and a vRay plane.
Everything works as it should until I selected one/any of lights and change any attribute. Vray plane disappears from RT, though it's 100% live and well in the scene. Things go back to normal only if I select vRay plane in the viewport and move/rotate/scale it. Then I undo that, and everything works fine. Until I select and change light again.
Of course, if I use maya's default geometry ( plane) there's no problems at all.
I attached screenshots. I use latest nightly build ( revision 22315) with maya 2013.
Hope this will be helpful.
Cheers,
Dj.
Cheers,
Dj.
