Normal map - control strenght.
  • Normal map - control strenght.
    Stupid question. But how do I control strength of normal map ? :/
    If I use normal map in tangent space all goes grey
    as I know - no controlling possible.
    In 3D Max it is, but in Maya version not!
    U´ve to tune it in Shader Map or such utils...
    Vray 3.5, Win10
    www.3dcompani.com
      thats bad ! I have to see if multiply node would work... not sure :/
        Blend the normal map with a solid color with value RGB 0.5, 0.5, 1.0 (in floating point).
          Solid color, you mean layered texture tool ?
          And how can I make it more bumpy? - is it possible.
            Use a blendcolor node
            Color 1 : RGB 0.5, 0.5, 1.0
            Color 2 : your normal map
            Connect your blendcolor into the bump of your material.
            In the blendcolor, if you set tje blend to 0, you will have your normal map, if you set your blend to 1, you will have no normal map, 0.5, less normal map.
            www.deex.info
              Yup I know how to make it weaker, how do I make it stronger, add more contrast?
                Vlado just curious why its not possible to directly control the stregth of the normal bump in the shader?
                Dmitry Vinnik
                Silhouette Images Inc.
                ShowReel:
                  There is no particular reason; it's just not done. I've made a note to look into it.
                    This has been fixed in the latest nightly.
                    Best,
                    Emil
                    V-Ray for Maya developer
                      Cool thanks ! It works for car paints too ?
                        Was'nt working for car paints, but it is now
                        Will be available in the next nightly.
                        Best,
                        Emil
                          Awww you guys are soooooo awesome !!!!!! Great thanks.
