Hey all,
I had hoped my first post would be something more positive but I've hit a major snag with RT.
I've done a couple of searches to see if anyone else has had this problem but I haven't found any usable results.
I recent upgraded from vray 1.5 to vray 2.3 so I could use vray in maya 2013 and also use the RT function.
I have no problem setting of a normal render but I just can't get RT to work.
The instructions I have found to use vrayRT are as follows: Render an IPR frame... then it should work!
But everytime I try (with different scenes and also very simple scenes) nothing happens except I get a 'scene is empty' warning in maya and in the maya renderview it asks me to 'select a region to begin tuning for vray'. Nothing else happens except a unix shell pops up telling me lots info including 'error: Failed to start network server: Failed to open listening port (4
'. Which seems to indicate I need to set up distribution rendering which doesn't match the docs...
Could I be doing some thing wrong? Anyone see any obvious issues? Anyone seen this before?
I've included the logs/outputs below.
Thanks in advance!
These are the logs/outputs I get:
(I haven't included the console window log/output because it's too long, but can include it if needed)
maya script editor:
// Warning: [SettingsPNG] No image writer specified. //
// Warning: [SettingsEXR] No image writer specified. //
// Warning: [SettingsTGA] No image writer specified. //
// Warning: [SettingsTIFF] No image writer specified. //
// Warning: [SettingsSGI] No image writer specified. //
// Warning: [SettingsJPEG] No image writer specified. //
// Warning: Scene is empty. //
Bash shell (unix shell):
[2012/Sep/26|11:29:40] Reading configuration from "/Applications/Autodesk/maya2013/vray/bin//vrayconfig.xml"
[2012/Sep/26|11:29:40] ===============================================
[2012/Sep/26|11:29:40] V-Ray Standalone, version 2.20.01 for x64
[2012/Sep/26|11:29:40] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved.
[2012/Sep/26|11:29:40] Use -credits option for additional third-party copyright notices.
[2012/Sep/26|11:29:40] Build from May 29 2012, 12:56:52
[2012/Sep/26|11:29:40] Compiled with GCC-compatible compiler, version 4.2
[2012/Sep/26|11:29:40] Operating system is Mac OS X
[2012/Sep/26|11:29:40] V-Ray core version is 2.00.01
[2012/Sep/26|11:29:40] Loading plugins from "/Applications/Autodesk/maya2013/vray/vrayplugins/libvray_*.so"
[2012/Sep/26|11:29:41] 102 plugin(s) loaded successfully
[2012/Sep/26|11:29:41] Finished loading plugins.
[2012/Sep/26|11:29:41] error: Failed to start network server: Failed to open listening port (4
[2012/Sep/26|11:29:41] Exiting server mode.
[2012/Sep/26|11:29:41] Closing log - 1 error(s), 0 warning(s).
logout
[Process completed]
Thanks in advance!
maya script editor:
logout
[Process completed]
