Vray / Python - odd shape node behavior when renaming
  • Vray / Python - odd shape node behavior when renaming
    Heya
    I have a little problem. I'm writing a script where it will create a render layer per light and rename it but the way light renaming works is a bit odd.
    Here is the problem.
    If I have maya Area light and rename it to Light
    I will have
    Transform node : Light
    Shape node : LightShape
    With vray lights I get this
    Shape node : Light
    Now I try to specify shape node or transform but none of it work I always get an error ValueError: More than one object matches name: VL__gfsdagh #
    any chance to get it tweaked for next nightly? :s so its nameShape.
    thanks, bye.
    Originally posted by DADAL View Post
    Heya
    I will have
    Shape node : Light
    thanks, bye.
    It is a Maya error, not Vray.
    You already have a light with the name "Light". It is why you have this error.
    www.deex.info
      Heya
      I will have
      Shape node : Light
      thanks, bye.
      www.deex.info
