VRay Render Elements window problem
  • VRay Render Elements window problem
    OK all of a sudden the window for the render elements has stopped displaying correctly... (please see image) is there a way to reset this ?
    I've restarted maya , the computer , re-installed vray but no luck , the problem is specific to a particular scene so I have exported all to a new scene but was wondering if there was a way to fix this....
    in the Script editor has a message :- // Error: No object matches name: VRayRenderElementSet1.enabled //
    any ideas whats going on here ?
    thanks in advance
    ignuf
    Which version of V-Ray / Maya does this happen with? Is it possible to provide us with the scene that is causing the problem?
    yolov
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      I don't know if it is the same problem but, for example, if i create a renderLayer, add an override to the render engine, and i switch between renderLayer with render global opened, sometime the render global of VRay is broken.
      www.deex.info
        sounds like something I could've done.. ill check to see if I can re-create, thanks bigbossfr
          hi Yolov, I'm using Maya 2013 and the output window is printing this :-
          [2013/Feb/21|21:17:34] V-Ray: V-Ray for Maya version 2.30.01 from May 11 2012, 01:51:11
          [2013/Feb/21|21:17:34] V-Ray: V-Ray core version is 2.00.01
          i'll see if I can simplify the scene and send on.
          regards
          Guy
            regards
            Guy
            This is a old VRay, the official build.
            If you can try with a stable build, it will be great.
            www.deex.info
              Was the scene last saved wih the same versions of V-Ray and Maya? I'll have to check wih the 2.30, I remember coming across something similar with a scene from a very old official build and then opening it with a newer one. I'll get back to you when I double check this.
              yolov
              Alex Yolov
              Product Manager
              www.chaos.com
                Hi bigbossfr,
                that's the latest version that I have available to me at the moment, what is the latest stable version at the moment ?
                  Hi bigbossfr,
                  You can email our support@chaosgroup.com to get access to those.
                  /yolov
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    Hi Yolov, that be great, i did ask a little while ago to subscribe to the nightly builds but for some reason didn't manage to get access. I'll try again and hope for the best.
                    regards
                    ignuf
