ObjectID and VRmesh with subdiv or displacement
  • ObjectID and VRmesh with subdiv or displacement
    explanation:
    I have several meshes.
    I put objectID attributes on every shapes (excepted 1 or 2, because I forgot them) then I exported all the shapes in 1 proxy.
    In a new file I import the proxy, then I do a render with ObjectID renderElement. everything goes fine.
    and then....
    I assign VRayDisplacement Node to the proxy, and I add displacement and subdiv attributes and render again...
    The result is a message like this: "Face texture index out of range", and my proxy disappears in the render.
    If I add the missing ObjectID attributes to the forgotten shapes, and do it again... everything is fixed
    In my tests: If one or more shapes are not tagged with ObjectID attribute, and, if Subdivision or Displacement is active on the VRayDisplacement node (or if you added nothing to the node, so displace is active by default)... as a result the proxy disappear at the render time.
    In the same kind of situation... it's impossible to render the ObjectID renderElement from a proxy if it has a VRaydispalcement node applyed (even with all the shapes tagged with the ObjectID attributes)
    The result is black
    Tested on the lastest Nightly
    Is it fixable?
    thank you
    Bug confirmed., proxy disappear (last nightly)
    www.deex.info
      Any news please ?
      www.deex.info
        Thank you guys - we have the same results here.
        I'll make a note about it into our system and I'll inform you when we have it fixed.
          Do you think it could be fixed fast, or do we have to find a workaround for the next weeks?
          I'm talking about the 2nd point (black renderElement). the first point is not pressing.
          it's only about my schedule and workflow on my current production.....
          thank you
            Hi BenDel,
            Unfortunately we can't give any time frame about those Object ID fixes, our developers are working on them.
            Tashko Zashev | chaos.com
              Hello everyone,
              We would like to inform you that this issue has been fixed in Vray 3.0 beta version.
              Thank you very much for your collaboration.
