Hi, I'm not sure whether the physicality of vray is just out of my minds reach right now or something is broken in the nightlies. I'm trying to create an Aqueous fluid around an eyeball geometry layer. I think I remember in the first versions of Vray 2.0 being able to just turn up the refraction color to white and that would make a surface transparent. Unfortunately I can't see anything that is directly behind the refracted geometry. I'm using an IOR of 1.37 and the refracted surface does have a slight thickness (extruded polys). If I move the opacity slider ever so slightly, the surface completely disappears, which I find odd too. I guess I'm just reall confused about what I'm seeing and why I can't see the opaque geometry that is behind the refracted aqueous.
Can I get some hints on what might be wrong. This is just plain odd, as I've never had this issue with other renderers.
