EXR different all of a sudden
  • EXR different all of a sudden
    Has something changed in the way VRay saves EXR files?
    I'm not using multichannel but with the scene i'm working with right now, the passes like reflection and specular are transparant?? which causes all manner of problems when i try to comp it in Photoshop.
    Which build are you using?
      i was using the 22501 build to osx maya 2014 from October 1st.
      i've just upgraded to the 24501 build from december 6th to try and see if that helps...
        ok so i still does it.
        But i think it is a issue with Photoshop CC perhaps? When i open as alpha and not transparency is works as expedted. And it blends or add the layers correct. The wierd thing is that i was never an issue before to open an exr as transparency.
          I've had this before. Didnt find a solution for it, just had to disable the alpha channel and the frames read as expected.
