Double posted, please delete.
Alpha VRayMtl Blend problem with domelight
This is because the Color+Alpha is also set for the Reflection Layer.
The Reflection Layer always overrides Refraction one - in this case the glass objects reflects the floor/ceiling objects and that's why the alpha channel gets white.
Here what happens if Affect Channel is set to Color Only for Reflection Layer:
Originally posted by svetlozar_draganov View PostThis is because the Color+Alpha is also set for the Reflection Layer.
[ATTACH=CONFIG]21792[/ATTACH]
Btw, if you are only using the V-Ray sky, it might better to not use a dome light at all, just use it as GI environment map.Maya 2020/2022
Win 10x64
Vray 5
Originally posted by snivlem View PostThank you very much Svetlozar, that was really confusing for me. For some reason I thought that if a reflection of ".1" would also mean that the alpha is also ".1" but it seems obviously this isn't the case.
