Rendering Yeti Fur !?!?
  • Rendering Yeti Fur !?!?
    Hi does anyone run yeti? I have a rial version from peregrine labs but i cant for the life of me get it to work with vray?
    i think its an environment variables issue. Basically i can run the plug in but cant get the fur to render it doesn't show.
    i have contacted yeti support but they were very unhelpful. as you can see from the below email.
    can anyone help with the install ? the latest error is in the email. im running vray Build 2.45.......
    Thanks James
    Hi James,
    That looks like it's a VRay issue.
    Thank you
    -- Peregrine Labs Support support@peregrinelabs.com -----Original Message----- From: "James Aston" <james@deliciousedit.co.uk> Reply-To: "James Aston" <james@deliciousedit.co.uk> Date: Tue, 04 Feb 2014 17:47:29 +0000 To: "support@peregrinelabs.com" <support@peregrinelabs.com> Subject: Re: (Case 1770) Yeti Trial Request
    > can someone please assist on the following maya error?
    > Thanks
    > james
    > // Error: line 1: Unable to dynamically load : C:/Program
    > Files/Autodesk/Maya2013/vray/plug-ins/vrayformaya.mll
    > Invalid access to memory location.
    > // Error: line 1: Invalid access to memory location.
    > (vrayformaya) //
    > select -cl ;
    It looks like V-Ray itself is not installed properly.
    Make sure that the environment variables VRAY_FOR_MAYA2013_MAIN_x64 and VRAY_FOR_MAYA2013_PLUGINS_x64 are correctly set (the first normally to "C:\Program Files\Autodesk\Maya2013/vray" without the quotes and second normally to "C:\Program Files\Autodesk\Maya2013/vray/vrayplugins" with the path to vray_pgYetiVRay.dll appended).
    If you just installed V-Ray, it might be useful to log out and log in again; sometimes Windows doesn't immediately pick up the change to the environment variables made by the installer.
      As Vlado pointed out, you should double check your vray installation. How did you install vray? do you have a correct vray for maya version?
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
