getting bad exports from V-ray for maya. Will not render Standalone please help!
  • getting bad exports from V-ray for maya. Will not render Standalone please help!
    I have enabled the export and disabled rendering in the translator tab.
    "there really should just be an export Button right here"
    hit render current frame. everything exports.
    I execute my render command, it goes thru its thing gets down to reading my file and I see.
    3Dm-Defiant:~ jbarnette$ /Applications/Autodesk/maya2014/vray/bin/vray -sceneFile=/Volumes/Projects/MyProject/scenes/LNG_Port_ENV_Animation_Camera_02_no_Ship.vrscene -frames=1-4,1
    [2014/Mar/5|09:55:19] Reading configuration from "/Applications/Autodesk/maya2014/vray/bin//vrayconfig.xml"
    [2014/Mar/5|09:55:19] ===============================================
    [2014/Mar/5|09:55:19] V-Ray Standalone, version 2.25.01 for x64
    [2014/Mar/5|09:55:19] Copyright (C) 2000-2012 Chaos Group Ltd. All rights reserved.
    [2014/Mar/5|09:55:19] Use -credits option for additional third-party copyright notices.
    [2014/Mar/5|09:55:19] Build 24239 from Feb 25 2014, 16:58:33
    [2014/Mar/5|09:55:19] Compiled with GCC-compatible compiler, version 4.2
    [2014/Mar/5|09:55:19] Operating system is Mac OS X
    [2014/Mar/5|09:55:19] V-Ray core version is 2.00.02
    [2014/Mar/5|09:55:20] Loading plugins from "/Applications/Autodesk/maya2014/vray/vrayplugins/libvray_*.so"
    [2014/Mar/5|09:55:20] 113 plugin(s) loaded successfully
    [2014/Mar/5|09:55:20] Loading plugins from "/Applications/Autodesk/maya2014/vray/vrayplugins/libstd_*.so"
    [2014/Mar/5|09:55:20] Finished loading plugins.
    [2014/Mar/5|09:55:20] Reading scene file "/Volumes/Projects/MyProject/scenes/LNG_Port_ENV_Animation_Camera_02_no_Ship.vrscene"
    [2014/Mar/5|09:55:20] error: Error in file "/Volumes/Projects/MyProject/scenes/LNG_Port_ENV_Animation_Camera_02_no_Ship.vrscene", line 991: Expected identifier
    [2014/Mar/5|09:55:20] Closing log - 1 error(s), 0 warning(s).
    Please advise I'm really behind here.
    UPDATE:
    Ok if I don't do export separate files for all of the lighting and everything and have it export just one file for the whole scene. It seems to render.
    Ok, but still can you show me line 991 from the scene file that gives the error? It sounds like a bug that we should fix.
      how do I do that just open in a text editor? do I have to turn compression off?
        It's a text file so yes you can open in any editor. No need to turn compression off.
          line 954 this time I had to re-export. but it happens anything separate file is checked.
          see image
Name:	Screen Shot 2014-03-05 at 12.20.26 PM.png
            Ok - will look into it. Thanks for the pointer!
              Hi, 3DMotif,
              We were unable to reproduce the issue with a similar scene: includes for geometry, textures etc., followed by comments and empty renderviews.
              Can you provide us with a scene for further investigation?
              Regards
              Nikola Goranov
              Chaos Developer
