Dome light with hdri not showing in ipr with rt
  • Dome light with hdri not showing in ipr with rt
    Hello there, I'm currently testing the GPU rendering with VRay 3 and I'm having issues with certain objects in the IPR. I have some simple primitives in the scene with various shaders on and a couple of lights. I also have a dome light with a HDRI attached. Everything renders but this.
    Any help on this would be great. Thanks
    VRay3.00.01 with a Quadro K6000
    KEITH ROGERS
    Learn the rules like a pro so you can break them as an artist.
    http://www.3layersofparallax.com/
    Have you looked at this table: http://docs.chaosgroup.com/display/V...orted+Features ?
    It shows what is expected to work and what isn't.
    If you still have problems after you remove the unsupported objects/shaders please sends us scene or post a bit more detailed description what you're expecting to happen and what happens in reality.
    V-Ray developer
      That's great and very interesting thank you. It's say's image based lighting is supported but having attached a HDRI to my dome light it stops working. Does it not support .HDR files. I can test this but I thought I might as well ask first.
      Regards
      Keith
      KEITH ROGERS
        Do you by any chance use a physical camera ?
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
          Ha ha no, it's the first thing I check usually.
          KEITH ROGERS
            It would be best to attach a scene here or send it to support@chaosgroup.com - .HDR images definitely work for dome lights.
              Thanks for the reply, I'll send it over first thing. I'm away from my work computer at the moment.
              Regards
              Keith
              KEITH ROGERS
                I've sent my scene with attached .HDR to support.
                Regards
                Keith
                KEITH ROGERS
                  Thank you very much for the scene.
                  I've just tested it and I can confirm that it worked with Maya 2015 and V-Ray 3.00.01.
                  Can you try to remove the Pre and Post Render MEL callbacks and run another test?
                  I don't have Yeti on my machine and I had to remove those callbacks in order to start the renderer.
                    Thanks for the reply, was that on the GPU with the IPR?
                    KEITH ROGERS
                      Yes - it was on the GPU(CUDA).
                        Oh, still doesn't work here. If I put a .jpg in the light texture it works, just not the .hdr. Which does work on the CPU. Strange. Click image for larger version
ID:	854714Click image for larger version
                        KEITH ROGERS
                          OK then, would it be possible to send us the logs from Maya' Output window and from V-Ray console after Cuda render.
                          Let us know also what OS you are using and what version.
                          What happens if you plug the HDR map into diffuse slot of the V-Ray material?
