Thanks, Svetlozar. That's an interesting workaround. Do you know what's the reason behind this bug/issue and why setting light subdivision to 1 will solve it?
Wrapper and multiple lights
+1 for me
Following this
Cheers DominikDominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
There might be a solution my dear colleague Martin (3v1L) came across:
- plug a useBackground in a vrayMaterialWrapper.
- in the MaterialWrapper make your settings e.g. matte surface, alpha contribiution -1.0, shadows, affect shadows, etc...
you get proper shadow catching without lowering your light samples.
Cheers!
Originally posted by Mr.Hoo View PostThere might be a solution my dear colleague Martin (3v1L) came across:
Cheers!
Dominik
Can you attach a sample scene?
I will prepare a scene and post it tomorrow!Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
Hey Svetlozar ,
you are right, I have to admit that it isn't working in my scene either.
But I've attached a scene for you, to cross-check:
shadow__testScene.zip
1. If you open and render on the "walkaround" render layer the setup should work fine (with the wrapper and the use background shader)
2. then change to the master layer, with all the other lights and then the setup breaks (you will see strange shadows)...
It seems, that if you add lights afterwards, it doesn't work anymore, for both the object property workflow and my suggestion.
Sad but true
Cheers
Yes, that's what I noticed too.
If you add a new light, it seems to work, but it sometimes accidently breaks for ever...
With the layers I wanted to show you the behaviorDominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
Hi Vlado!
is this fixed? If yes, in which version?
Thanks
