hi,
There's a problem with irradiance and alembic's animated visibility.
Make a plane, add an edge support and a vray subdivision attribute.
Parent the plane to a group
Animate visibility of the group then bake an alembic.
Load it in maya and you will see that irradiance map samples are generated on the plane without subdivision.
So the samples on the faces created by the edge support are deformed by the subdivision.
If you I could send you a file that recreate the problem.
What can I do ?
Thanks,
Max
What can I do ?
Thanks,
Max
