Proxy creation generates broken proxy in V-Ray 3 build 25592
  • Proxy creation generates broken proxy in V-Ray 3 build 25592
    We've noticed that when making some objects into proxies, they end up broken in this build. I've attached a tree, which ends up not having all branches intact if you make it into a proxy. Can you reproduce this on your end?
    The scene and the broken vrmesh: https://mega.co.nz/#!74ojWIja!tOgD0b...NJD15dMHEeNMzk
    We're on Win7 64-bit with Maya 2015 Extension 1, SP5 with V-Ray 3 nightly build 25592.
    Best Regards,
    Fredrik
    We recently fixed an issue that was breaking the proxy export. Can you try a newer night build (25691 from April 7 and later)?
    Just to confirm if it is the same thing, can you post your proxy export settings?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hi Alex,
      I just downloaded the latest nightly (25751 for Maya 2015) and I can now create a proxy from that mesh without an issue. So this seems to be fixed. I'm attaching the controls just in case...
      Best Regards,
      Fredrik
        Yes, I was late to update you here.
        The problem should be gone away now. Thanks for the input.
        Alex Yolov
        Product Manager
        www.chaos.com
