VRAY 3 Progessive Render on Farm
  • VRAY 3 Progessive Render on Farm
    Hi there, we are using VRAY 3.05.04.25445 on Linux. Locally (in Maya) we can set progressive rendering to 30 minutes and it works great, but when we put this on the farm, it renders in 30 minutes, but generates black frames. Is there any trick or setting that would need to be done to make this work. Is there any information I can give that would help debug this issue?
    Cheers,
    -Chris
    What file format are you saving to? Are you rendering through Maya or through V-Ray Standalone? Which Maya version? Can you post the output from the render?
      You will also run into another problem, unless all of your machines are identical by specs some machines may render for 30 minutes but produce grainier result since they are slower, so you will have discrepancy in frames done by different spec machines.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        Hopefully this information is helpful.
        EXR (Deep)
        Rendering Through Maya (Not Standalone)
        Maya Version 2015.1.5.09
        What would you need from the image, the actual file? The image itself is 100% black. If you need the image I would l have to look into what that would take on our end to get permission.
        Cheers,
        -Chris
          there is no deep support for progressive.... you will also get black frames if you render local...
            Hm, you should have gotten a warning that deep output is not supported in progressive mode yet.
              Weird no error message ever showed up. But will give it a try in another format.
              Cheers,
              -Chris
