Vray Light Material fails to show in Multimatte
  • Vray Light Material fails to show in Multimatte
    I have this light emitting VRay light material that I wanted to create a multimatte pass with, using material ID tags on the shader. I could not get the material to show up in my multimatte element until I turned off Direct Illumination on the light shader. I tried it consistently in test scenes. Once you turn on Direct Illumination, the shader doesn't pass into the multimatte anymore.
    Is this a feature, or a bug? I am working with maya 2015, and Vray 3.10.01. It would be nice to have consistent behavior.
    Raphael
    Not a bug, lets say a limitation Please use the Object IDs for Light materials with Direct ill. instead.
    Tashko Zashev | chaos.com
      Ok thanks. Maybe Vlado Claus can bring this for Christmas, one day.
