samplerInfo in VP2
  • samplerInfo in VP2
    In 3.40.02, V-Ray materials are now visible in VP2.0 which is absolutely awesome. However, we noticed if you have a samplerInfo node in your shader network, the shader won't appear in the viewport. It would be very useful if this was supported.
    Also, I couldn't get a V-Ray proxy to show up as shaded in VP2.0 ... perhaps this is a limitation which is not easily fixed?
    Cheers!
    Best Regards,
    Fredrik
    How about if you switch the Viewport 2.0 rendering engine to "OpenGL Core Profile" ( Preferences > Display > Viewport 2.0 )?
    You can get it to show up if you change the "Geometry to load" option of the VRayProxy to "Maya mesh"
    Miroslav Ivanov
    Chaos Cosmos
      That was actually what we had loaded when trying this. So it appears that didn't work.
      Hm, when I select the proxy and set it to "Maya mesh", it'll appear as completely solid light gray (no textures).
      This was all in Maya 2016, by the way.
      Best Regards,
      Fredrik
        Can you upload a simple scene demonstrating the samplerInfo issue? I tried connecting the facingRatio to various plugs on our materials and it seems to work fine in OpenGL Core profile, as long as you enable Textured view. In the old OpenGL profile we use a different implementation which doesn't support input connections so well.
        The gray color you're seeing on the proxies should be the "Viewport color" from VRayMeshMaterial. We currently don't display the original shaders and textures.
        Deyan Spirov
        V-Ray for Maya developer
