Nightlies give me a license error
  • Nightlies give me a license error
    the last working nightly for maya 2017 on Windows 8.1 is vray_adv_35501_maya2017_x64_27163
    since vray_adv_35501_maya2017_x64_27172 I always get a license error:
    // Error: Could not obtain an interface license (-200)!
    I switched back to 27163 and that works again.. I didn't find anything about that so I'm wondering if I'm the only one having this issue...
    edit: Also with the today's nightly for Maya 2016 I get the license error...
    best regards,
    sacha
    Hi, sorry to hear that you've run into an issue. We'll need a bit more information:
    * are you running the license server locally or in a network, i.e. on the same machine where you're using maya or on another machine in your network?
    * what is the version of your license server?
    * if you're running the license server on another machine - what is the OS on that machine?
    * how many machines are obtaining a license from that same license server, i.e. are there more than one machines getting a license from the same license server where multiple licenses are stored?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Can you also try if disabling swatch rendering fixes the problem? It's done from the maya menus > Windows > Rendering Editors > V-Ray > Render Swatches.
      Alex Yolov
      Product Manager
      www.chaos.com
        hey alex,
        * I'm running the license server on the same machine.
        * my ls version is 3.0 protocol ver.7
        * three machines are obtaining licenses from that server. there are multiple liceneses, I#m working with: maya 3.x and max 2.4 but I actually use always one software at a time, so the second and third machines are just
        render slaves.
        just downloaded the today´s version, unchecked the render swatches button but still running into the same issue...
        p.s. When editing the last post of a thread my original message is not shown in the edit window anymore...
        best regards,
        sacha
          It adds up to a bug that slipped in with build 27165. We actually already knew about it and we've been working on a fix since then, I just wanted to confirm.
          Thanks for the report and apologies for any inconvenience caused.
          I'll let you know when there's a fix.
          Alex Yolov
          Product Manager
          www.chaos.com
            So I have to wait until you fix it, before I can go for a version beyond 27164? Or is there any workaround?
            best regards,
            sacha
              Unfortunately - yes, you'll have to wait. Hopefully you won't have to wait too long.
              Alex Yolov
              Product Manager
              www.chaos.com
                Guess I am experiencing a similar issue. I am running Maya 2017 x64 on Win 7.
                I was able to render with vray_adv_35501_maya2017_x64_27164 but today after I installed vray_adv_35701_maya2017_x64_27198, I got the same error.
                Code:
                [COLOR=#3E3E3E]// Error: Could not obtain an interface license (-200)![/COLOR]
                always curious...
                  As workaround you can check env path VRAY_AUTH_CLIENT_FILE_PATH
                  In my case when it local, all works fine. But when it network path, I have same issue.
                    Hi, can you post the exact string containing the V-Ray version when it is loaded in Maya? It should be in the Output Window and should be something like this:
                    "V-Ray for Maya version 3.55.01 from Feb 3 2017, 16:54:07".
                    Deyan Hadzhiev
                    Developer
                    chaos.com
                      Hi, Please check if the last nightly build fixes your problems (build 27204).
                      Deyan Hadzhiev
                      Developer
                      chaos.com
                        I tested with build 27199 and it worked fine.
                        always curious...
                          Thanks for confirming.
                          Alex Yolov
                          Product Manager
                          www.chaos.com
                            thanks for fixing and I noticed, that also the issue http://forums.chaosgroup.com/showthr...-VFB-distorted is fixed. Great!
                            best regards,
                            sacha
