Cannot find procedure "shaderBallRendererMenuUpdate".
  • Cannot find procedure "shaderBallRendererMenuUpdate".
    When commandline rendering using Maya, we always get this error:
    Code:
    The error itself doesn't seem to affect the render and the render completes just fine. However, this becomes an issue since all errors during rendering are being submitted into a Slack channel. This error completely spams the channel as it *always* is being hit on every single render.
    What could be causing this to happen?
    The error appears in this context which causes me to think it could be related to V-Ray:
    Code:
    [2017/Feb/16|14:04:25] V-Ray: V-Ray for Maya version 3.40.06, revision 27073 from Nov 22 2016, 21:23:16
    [2017/Feb/16|14:04:25] V-Ray: V-Ray core version is 3.25.01
    Initializing V-Ray for Maya
    [2017/Feb/16|14:04:25] V-Ray: Loading plugins from "//192.168.0.226/pipeline/bin/vray/builds/161122_vray_v3.40.06-b27073-stable-maya2017_win64/maya_vray/vrayplugins/vray_*.dll"
    [2017/Feb/16|14:04:29] V-Ray: 75 plugin(s) loaded successfully
    [2017/Feb/16|14:04:29] V-Ray: Finished loading plugins.
    [2017/Feb/16|14:04:31] V-Ray: Registered dynamic node vrayMultiProjection (id: 1115335/0x001104C7)
    [2017/Feb/16|14:04:31] V-Ray: Registered dynamic node VRayCurvature (id: 1115347/0x001104D3)
    [2017/Feb/16|14:04:31] V-Ray: Registered dynamic node VRayTriplanar (id: 1115362/0x001104E2)
    [2017/Feb/16|14:04:31] V-Ray: Registered dynamic node VRaySkinMtl (id: 1115348/0x001104D4)
    [2017/Feb/16|14:04:31] V-Ray: Registered dynamic node VRayPointParticleMtl (id: 1115353/0x001104D9)
    [2017/Feb/16|14:04:31] V-Ray: Registered dynamic node VRayStochasticFlakesMtl (id: 1115359/0x001104DF)
    Error: line 1: line 1: Cannot find procedure "shaderBallRendererMenuUpdate".
    File read in  8.3 seconds.
    Result: //192.168.0.226/prod/proj2/maya/scenes/scene68.mb
    Have you seen this before and/or have any idea why it might be happening?
    Best Regards,
    Fredrik
    I have come across this before and I think it's Maya itself. shaderBallRendererMenuUpdate is related to the new material viewer in the hypershade. Not sure what the problem is exactly, though.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Thanks Yolov. You're right, it wasn't V-Ray.
      Best Regards,
      Fredrik
