Bifrost Cached Liquid Batch Render - Wrong
  • Bifrost Cached Liquid Batch Render - Wrong
    I have a disk cached bifrost liquid sim that renders correctly in the v-ray frame buffer window, if I render a single frame.
    If I run a batch render, it renders the bifrost liquid but doesn't use the cached sim animation. The liquid appears in the render but isn't animated like the cached sim.
    If I render a frame range to the frame buffer window directly, it is also wrong, it looks the same as the batch render.
    See attached images.
    Has anyone experienced this? Is there a workaround, like a script to render each frame into the buffer window, save the image, etc.
    I'm running Maya 2017 update 4, Vray 3.52.03 on Windows 10.
ID:	961846Click image for larger version
    Noted, thanks for the report. It seems that this is a bug.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Hi was this ever fixed? Having the same issue with Maya 2018, vray 3.60.03
        Thanks for the reminder, but unfortunately this still doesn't work. We will raise its priority additionally. Sorry for your trouble.
        Svetlana Gesheva
        QA, V-Ray for Maya
        chaos
          See if enabling meshing helps in this case (in liquidShape > Bifrost Meshing > Enable).
          We'll work to improve bifrost support in the future.
          Alex Yolov
          Product Manager
          www.chaos.com
            Is this not resolved in V-Ray 5?
            Even with V-Ray 5.2, direct rendering of Biforst Mesh does not work with BatchRender.
            OakCorp Japan - Yuji Yamauchi
            oakcorp.net
            v-ray.jp
