IPR v Progressive difference in reflection
  • IPR v Progressive difference in reflection
    ^ IPR version
    ^ Progressive version
    Is there a reason for why this could occure? Just using a standar VRayMtl with a reflection fresnel of 1.6
    Maya 2020/2022
    Win 10x64
    Vray 5
    Is this IPR CPU or GPU? It might be the GI - the IPR only supports BF+BF, while the progressive supports any combination of all available GI modes.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Ah, will test on Monday.
      It's the IPR CPU.
      Main render is BF + LC, so that might explain why it's different. Thanks Alex.
      Maya 2020/2022
      Win 10x64
      Vray 5
        are you referring to the angled reflection in the window? It might be a difference in reflection/refraction bounce depth. If I'm not mistaken, the bounce depth in the IPR tab will stop at 5 (default), if your material has greater than 5 those extra bounces won't show up in IPR unless you raise that in the settings. Although, the standard material defaults to 5 as well... so unless you've changed that this isn't the issue.
        www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
