Creating Maya plugin for V-Ray shader
  • Creating Maya plugin for V-Ray shader
    Hello,
    I have created some custom V-Ray plugins for Maya which I can access using the Create->V-Ray->Create from V-Ray Plugin. I'd now like to improve the user interface so I've been trying to follow the instructions in the "V-Ray for Maya translator SDK" -> Shaders section of the documentation to create the accompanying Maya plugin.
    I have used the vrayblinnmtl files from the vray/samples folder as a test shader, I've compiled the Maya plugin from this folder which I can now load from the Plug-in Manager in Maya (I had to add initializePlugin and uninitializePlugin methods for it to work) and I've added the shader description to desc.txt (shader description taken from samples/maya_plugins/vrayblinnmtl/readme.txt). However, I still can't see the material in the Hypershade...
    Any ideas on what I'm missing?
    Any help would be much appreciated!
    Thanks very much,
    Lindsey
    Probably you've missed some of the steps in "Creating the Maya plugin".
    Have you verified that you've done them all?
    Also have you loaded your plugin?
    V-Ray developer
      If the shader loads in Maya, there is no reason why it will not show up in HyperShade... is this on Windows or Linux?
        Hello,
        Thank you for the replies - I have found the problem! I was testing with the vrayblinnmtl from the samples but what I had not noticed was that there was a separate cpp file with initialize and uninitialize functions - now I've compiled it using those specific ones (I had used more general ones before) it works perfectly.
        Thanks very much for the help,
        Lindsey
          Ah ok then. Btw V-Ray 3.0 and the latest nightly builds of V-Ray 2.45 can automatically create hypershade nodes without the need of a special Maya plugin.
            Ah ok, that's good to know. Thanks Vlado!
            Lindsey
