velocity channel in vrscene
  • velocity channel in vrscene
    Hi there,
    I was wondering if Vray supports deformation blur defined on the vrscene level. At them moment I'm working with positions, normals and map_channels. Is it possible to add velocity as well? What keyword should I use?
    Thank you,
    kuba
    The GeomMeshPlugin has a parameter called "velocities", which is a list of Vector's with the object vertex velocities, in scene units per frame.
    Alternatively, you can use interpolate() statements for the positions and specify different values at different frames - this will enable V-Ray to do deformation blur as well.
      Hey Vlado,
      Thanks for quick reply I'll give it a shot.
      Btw. It's easier to get hold of you on the forum then on Siggraph. Tried a few times with no luck
        Yes, when I was not in meetings, I went to see the talks and papers sessions; it's the first Siggraph that I've not been rooted at the booth and it is a nice change
