Render incorrect when different geometries
  • Render incorrect when different geometries
    I am currently developing a Maya plugin that creates multiple MPxNodes (same type) and assigns shapes to these Nodes.
    When Vray-rendering, each MPxNode is creating and registering a vrayplugin, sends the geometry using a geomMeshLoader.
    If I have the same shape for all nodes, the result is correct. However as soon as I have at least 2 different shapes, the output is incorrect.
    See image with 5 MPxNodes in my scene:
    The generated vrscene files are the following (please note that my plugin is not exporting geomStaticMesh geometry to the vrscene, there is another ticket open for this in the forum):
    http://www.petits-suisses.ch/cube.vrscene
    http://www.petits-suisses.ch/mix.vrscene
    If I output some logs from my code, I can see that the proper geometry is passed to Vray.
    Would you have any idea what this could be or would you need some additional information ?
    Thanks.
    Found the issue. I was assigning static parameters to the plugin, instead of "newing" them before each shape.
      Ok, glad that you found the issue! Please post if you have other problems.
