For that to work you have to use Additive blending and then you can easily break energy conservation. It'd be best to have coat layer within an energy conserving material like Arnold/Renderman etc.
This is the method I have had recommended to preserve energy conservation is to make the second spec with fresnel disabled (so it's just 100% reflective), then use a vrayFresnel node to blend between that and the original material.
Though I don't know if it's strictly accurate, maybe someone at Chaos Group can confirm? If not, I think I would sooner have a more robust officially sanctioned shader or workflow too add any arbitrary amount of films and coatings to any material (So it would also work with SSS2, StochasticFlakes, OSL, raw BRDFs, etc.), and also support things like glossyfresnel.
Yes, we do plan to add a coat layer, although I'm not sure when it will get into a build yet.
Great to hear! I was loosing faith that it will ever happen.
It'll be a seperate material to use in the blend mtl, not an additional reflection layer in the standart mtl right?
We have to do a layer in the regular VRayMtl material in any case so we will do that first. A separate material with proper glossy Fresnel support for the blend material turned out to be more complicated, especially on the GPU, so it will have to be done as a second step.
wizlon would you share any material cases which would benefit from it? First thing I can think of is lacquered wood? Anything painted with a clear coat I guess?
My Artstation
Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -Sun Tsu
