Interior toon line
  • Interior toon line
Name:	Clipboard Image.jpg
ID:	1204731 Click image for larger version
Name:	Clipboard Image (1).jpg
    On Domestika website there is a great tutorial for this kind of effect where you can get an internal details when using toon line.
    https://www.domestika.org/en/courses...with-arnold​
    Could we have this for VRay?
    Hi, thanks for posting. I am not sure what details you mean? There are maps slots with the current VRayToon that you can use to add detail.
    Vladimir Krastev | chaos.com
      The toon effect in arnold can trace from a greeble texture map. When plugged into a ramp you can very the effect.
        Could you share an example of this feature with a short explanation if possible?
          Here is a link to best show the effect of edge detection with toon.
          These are 2 clips from the training course which best explain the technique, you can simply skip through the shots to get the gist of the technique. of edge detection from texture files with toon.
          https://drive.google.com/drive/folde...usp=drive_link
            VRayToonMtl > Toon Edges Override > "Mask Colour Threshold" cannot do this?
            https://docs.chaos.com/display/VMAYA/VRayToonMtl
            OakCorp Japan - Yuji Yamauchi
            oakcorp.net
            v-ray.jp
              Yes it can! I was using a black and white image which didnt work it had to be colour.
              Hey Flat, thanks for the pointer worked a treat.
