chaos scatter scale options
  • chaos scatter scale options
    I cant see a way to control a scatter with a ramp, but also have scale variation within that ramp control....so for example...if I have a ramp circle to create a falloff for a scatter of grass, Id want the tallest grass in the center, and it getting smaller to the outer edges. I would still like to be able to control variation within that ramp control. If I use a ramp to control scale, it means I cant have variation within that. Basically itd be great to have layered scale control....so I can set a ramp for overall 1.0 to 0.1, but within that there is more scale variation to break up the uniformity of the objects.
    Website
    https://mangobeard.com/
    Behance
    https://www.behance.net/seandunderdale
    Hi, thanks for posting. You could blend more than one map to gain more control over the scale. For example here I have used a ramp and a noise connected to a colorComposite:
    Vladimir Krastev | chaos.com
      That does look like a nice solution, thanks for that!
      Website
      Behance
