Tried to rename it to st2 also in the UV editor. Does not work in Vray.
Arnold does work with map2 and st2.
I get this warning. Maybe thats the main cause.
// Warning: line 1: V-Ray : MaterialX: Unsupported node type "ND_adsk_converter_float"
// Warning: line 1: V-Ray : MaterialX: Unsupported node type "ND_separate4_multioutput"
I tested it with V-Ray and it worked. But, yes, those two nodes are probably the reason.
