Layer override with batch render camera
  • Layer override with batch render camera
    Is it possible to add the layer override command to the batch render camera settings in the VRay Common tab? See attached picture for reference.
    This quite useful to render different cameras with different settings within the same scene
    Thanks.
    Maya 2020/2022
    Win 10x64
    Vray 5
    EDIT: removed
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
      Hey snivlem,
      u can already work around that problem with some scripting
      select your renderlayer and put that in your script editor - of course you need to change "yourRenderlayerCam" to your camera name
      Code:
      editRenderLayerAdjustment "vraySettings.batchCamera";
      setAttr -type "string" vraySettings.batchCamera "yourRenderlayerCam";
      hope that helps!
      Oli
        Thanks for the pointer; this is logged and we'll work on it.
