Double Sided Displacement
  • Double Sided Displacement
    Hey Guys,
    in renderman there is a feature which is called "double shade" and it is extremely usefull when u displace stuff on a plane and u want to get a solid object...this options "mirros" the displacement on the object....one can then use a opacity map to cut off the non-displaced part of the plane.
    Is it possible to implement such a feature?
    If i wasn't clear enough i can post images later!
    thx
    Oli
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    Can you not do it if you just duplicate the geometry with inversed normals?
      Yes! That would be the inconvenient way
      Do you think this could be implemented as a displacement-option as well?!? PEEEAAASSSEEEE
      cheerio
      Oli
