Vray Toon on curves.
  • Vray Toon on curves.
    The VrayToon is a great feature, but will it be possible so that it can be added to Maya's curves (CV curves, EP curves etc...)?
    Edit: Rather than starting on a new thread, is it also possible to have Maya's group nodes with the "Include/Exclude" UI list? So we can add multiple objects at once using groups rather than individual objects.
    Is it also possible to create more than line style? If not I guess then Maya Toon would be the more appropriate system to use.
    THanks.
    Maya 2020/2022
    Win 10x64
    Vray 5
    Hm, VRayToon works fine with curves from what I could test - just make sure that you have added the V-Ray "Renderable" attributes to the curves and made them renderable.
    Will make a note about the group nodes.
    For the styles, some simple styles can be implemented by mapping the line color or width.
      Thank you Vlado. I'll try this tomorrow.
      Sorry! I think I made a typo. I meant to say "Is it also possible to create more than one line style?". It is no problem though because V-Ray can support basic Maya Toon lines, so I will be able to mix different multiple line styles with V-Ray Toon.
      Thanks for the pointers.
      Maya 2020/2022
      Win 10x64
      Vray 5
        Well, right now you can create only one VRayToon node from the Create > V-Ray menu, but technically nothing prevents you from creating more than one VRayToon node with different settings and different object sets... this part will have to be reworked to make the process easier though.
          Thank you Vlado.
          I've been away over the holidays but came back and installed the Jan 16 2011 build with Maya 2011 x64 Hotfix 3.
          When adding the "Renderable" attribute to a basic CV curve and selecting the "Render" tickbox, V-Ray encounters a fatal error when compiling the scene.
          See attached, it seems to be reproducible.
          1) Create CV curve
          2) Add "Renderable" attribute
          3) Create Vray Toon and add the curve.
          vraytoon.zip
          Maya 2020/2022
          Win 10x64
          Vray 5
            Yep, I can reproduce the crash; will fix it. In the meantime, it will work if you do not include the curve in the VRayToon set and setting the type of the set to "exclude".
              Sorry to be such a pain Vlado, but using that method there seems to be another bug with the Jan 16th build.
              With another attached scene I have uploaded, V-Ray RT will display the curve properly, however a standard V-Ray render will show the curve an extra four times (the curve is duplicated multiple times).
              vraytoonDuplicate.zip
              Thank you for your patience I understand you are busy!
              RT Render
              Standard Render
              Maya 2020/2022
              Win 10x64
              Vray 5
                Okay, I see this is not exactly a bug per se. I think what I am seeing is a difference between the RT render (which is just showing the curve as a renderable object with a material) compared to the Standard Renderer which is showing that as well as the toon lines which explains the difference (as toon is not supported in RT??). Still not sure why I have multiple lines but probably just a setting.
                I have a question however, sometimes I'm required to work with DWG files, often these will import into Maya with 100's of curves. Is there a quicker way to add the "Renderable" attribute to all the curves than doing it one by one individually?
                Cheers
                Maya 2020/2022
                Win 10x64
                Vray 5
                  Hi, instead of creating another thread I thought I'd post here. I have attached a simple scene where the "Renderable" V-Ray node fails to render the curve properly.
                  curve.zip
                  However if I attatch a paintfx brush to the curve (Paint Effects > Curve Utilites > Attach Brush To Curves) it renders perfectly!?
                  Maya 2020/2022
                  Win 10x64
                  Vray 5
                    Thanks for the scene. Will try to figure out the problem.
                    About setting the attributes to many curves - you can write a script. Use this command to create the attributes:
                    vray addAttributesFromGroup <nodename> vray_nurbscurve_renderable 1;
                    Then, just set the attributes to whatever you want.
                      I have fixed the problem with the missing part of the curve. Will be in the next build
                        Thank you Ivaylo. Thanks for the tip with the script too!
                        Maya 2020/2022
                        Win 10x64
                        Vray 5
                          I'm playing around with toon and it's great!
                          I'm wondering how mapping the line width works though, does it take a value from the corresponding point in uv space?
                          I've tried mapping a ramp and checker to it on a mesh with uv's and then setting the value of the color to 3 or 4 but then my lines disappear..
                          any hints?
                          showreel: http://vimeo.com/27236919
                            Is there a way to get the toons lines supported/disabled in the Zdepth channel?
                            Maya 2020/2022
                            Win 10x64
                            Vray 5
                              Ah so you got to that You can try giving the lines a very slight opacity.
