Scaling Area Light drives the UV size
  • Scaling Area Light drives the UV size
    Now that we can scale Vray area light, could the scale drives the U and V size? and the other way around as well.
    Thanks,
    Yannick
    Portfolio: http://www.cgifocus.co.uk
    Hi Yannick. I guess this can already be down via the conenction editor in maya.
    But it would be nice to have a little check box under the Use Tex option to link texture repeat uv to light scale.
    Rich
      Originally posted by Yannick View Post
      Thanks,
      Yannick
      The effect of the transformation scale and the U/V size is cumulative; they both have an effect. So if one drives the other, you'll be effectlively applying the same scaling twice.
        Hi Vlado,
        thanks for your answer.
        It just feels we now have to scaling way that are doing the same.
        Maybe the UV size is now obsolete?
          Well, technically when you create a cube, you can also use scaling to change its size, so you don't need any parameters like length/width/height. Same for the sphere, torus etc. It's just more convenient to have those parameters than not.
            ok fair enough
