Render does not start and Modo crashes after
  • #16
    Yes, well my renders are used at business events and sometimes it is printed on a wall where people walk by. Then I need this kind of resolution
    • #17
      Originally posted by RobertRay View Post
      vladimir.nedev I'll will send you the file by wetransfer, it's a large file.
      Just took a look at the scene.
      It has a huge amount of part tags.
      This is caused by CAD import and slows down the translation from Modo to V-Ray a LOT.
      It also slows down other Modo operations making it harder to work on the scene.
      You can delete the part tags by selecting all your meshes (Select -> Item Types -> Meshes )
      and then executing a Geometry -> Polygon -> Set Part... command with a "Default" name for the tag.
      If you click on the drop-down menu in this command, you will see (after some waiting) all the part tags that are applied to polygons in the scene.
      Greetings,
      Vladimir Nedev
