Converting .vrmat to Modo V-Ray material?
  • Converting .vrmat to Modo V-Ray material?
    Like the topic, is it possible? Or is it possible to access the vrmat's properties from a script, so that I can make a converter myself?
    I just noticed that the vrmat files are some sort of xml like structured text files, should be pretty easy to create a converter script. I'll give it a try.
      It may be possible, however the .vrmat files can use shading nodes that do not have equivalents in Modo.
        Thanks, I'll see how far I get.
          I've had a quick look and started on a converter script. I noticed that RGB values go from 0.0 to 1.2. Why is that?
            Which RGB values?
              In the .vrmat file. Here's an example:
              <Asset url="/SuperTex/BRDFVRayMtl/translucency_color" type="texture" layout="" renderer="vray">
              <plugin>
              <vrayplugin name="TexCombineColor" type="texture">
              <parameters>
              <parameter handler="default" name="color" type="color">
              <value><r>1.2</r><g>1.2</g><b>1.2</b></value>
              </parameter>
              <parameter handler="default" name="texture" type="acolor texture">
              <value></value>
              </parameter>
              <parameter handler="default" name="texture_multiplier" type="float">
              <value>1.0</value>
              </parameter>
              </parameters>
              </vrayplugin>
              </plugin>
              </Asset>
              Which RGB values?
                In this particular case, someone probably wanted to boost the translucency result. But it's pointless anyways as V-Ray will clamp the colors internally.
                  That example is from a testing material I made myself in 3ds max. I just tried again in both max 2014 and 2015, if I set a color to 255,255,255, it comes out as 1.2 in the .vrmat file.
                    Also, I can't find the self illumination value in the .vrmat file. Is that not yet supported?
                      Then it seems like a conversion bug - will look into it.
                        Could you send us .vrmat file, please?
                        Also I would like to ask you do couple of steps and then test conversion again.
                        1. Open MaxScriptEditor from MaxScript main menu
                        2. File->Open... from <C:>\Program Files\Autodesk\3ds Max <2013,2015..>\scripts\Startup select vraymtlexport.ms and open it.
                        3. Press Ctrl + E or Tools->Evaluate All
                        Do the same (step 2 and 3) for vrvismatconvertor.ms
                        Anna
                        <plugin>
                        <parameters>
                        </parameter>
                        <value></value>
                        </parameter>
                        <value>1.0</value>
                        </parameter>
                        </parameters>
                        </vrayplugin>
                        </plugin>
                        </Asset>
                          Sure. Where do you want me to send it?
                          I did exactly what you described and the file came out the same, with 1.2 values.
                          Originally posted by anna.zaharieva View Post
                          Anna
                            Send it to anna@chaosgroup.com . Thanks!
                            And one more test, please
                            First evaluate vrvismatconvertor.ms and then vraymtlexport.ms.
                            Test conversion again.
                              We do plan on adding a vrscene material importer to V-Ray for MODO. It should be easy to make it work with vrmat files as well as these can be loaded as a vrscene internally.
                              The importer will probably have to resort to using nodal shading for more complex materials though. But first we need to get nodal shading working in V-Ray for MODO.
                              Greetings,
                              Vladimir Nedev
