Is it me or is the vrmats download link on the site not working? Even when logged into the chaosgroup website I cannot download the vrmat presets?
vrmats download?
Originally posted by toad32 View Postyes, that is the one! It will not let me log into my account. Even reset my password so I know that I am using the correct username
I will ask around who gets access, hopefully it will be possible to give it automatically to all V-Ray for MODO owners.
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
Originally posted by Robert View Post2. How to import them into Modo?
If the .vrmat file contains multiple materials, you then need to select the one you want to use.
The .vrmat format is basically a .vrscene with only materials stored in XML format.
It should be possible to extend the .vrscene import to work with .vrmat files.
Greetings,
Originally posted by Robert View PostThanks, but still no access to the page. Looking forward testing it.
You can send an e-mail to support@chaosgroup.com with your chaosgroup.com user-name, requesting access to that page and they should give it to you, manually.
Greetings,
Hello Vladimir, i've access to that page - http://www.chaosgroup.com/en/2/downl...-ray-materials - but i get Vray for Rhino/Sketchup Materials (i'm a Modo user/client), which don't look the same as the screen shot you post, at least they are not organized like that: i get several folders titled as Architectural, Automotive, Fabric, and so on. Maybe they are the same.
Anyway, i think we can't tweak those materials, even change basic stuff like color difuse, so i ask: will we get a Vrmat editor in Modo or standalone?
Also, will we get V-Ray 3.0 Quick Settings?
Thanks.
Carlos
1. V-Ray materials (Low Resolution Library)
2. V-Ray for Rhino / Sketchup Materials
I have access to 1., you seem to have access to 2.
Greetings,
Greetings,
I'm not sure if we need the whole scope of materials for Modo. Most Modo presets work very well with Vray. The things where it gets complicated and tricky are the ones interesting. I have an old 3dsmax where I can check that, in theory, because I currently have no own Windows machine.
Anyhow there are also lot resources in the internet. The best thing to start with is to get some samples in vrscene format. But also read about the difference and tricks how to use.. things can get very complex and frustrating in some cases, vray material is almost 20 years old and that means you have to go through all the additions over the years and ignore things you will never need.
One of the bigger things is that Modo divides between Color Value and RGB and ALPHA, Vray however always takes RGB for nearly everything, even if colors are not needed and might even produce wrong effects. So things like the RGBA effect in Modo are not working easy in schematic.
But its version 1.0.. things might improve.
Until we add the (updated) material library to the new site, you can download it from here : http://ftp.chaosgroup.com/support/VR...al_Library.zip
Greetings,
